1999 Chrysler Town and Country Door Handle
122,000 MILES • 6 CYL • FWD • AUTOMATIC
BDIAL
How do I replace the exterior driver door handle on my 1999 Chrysler Town and Country?
Jan 29, 2009 at 11:39 AM
  • 110,248 POSTS
Replacement is done from in the door. You will need to remove the door panel first. Once inside, disconnect the linkage from the old handle and there are two nuts that hold the old handle to the door. remove them and then remove the old handle. reverse the order to replace. NOTE: Space it tight, so be prepared for a few cuts.
Let me know if this helps.
Feb 3, 2009 at 10:42 AM
