have been having a problem with the door locks, they keep locking after the van is shut off the the key is out of the ignition, if i don't lock it after leaving it, the van will lock it self and then every 30 seconds lock over and over , this also happen when i do lock the van, this goes on and on .... have taken key fob apart and replaced batteries, have taken fuses out and replaced them, have tried taking the battery out so the brain would have to reboot......even tried it on the problem anylizer but that only works when the van is on, this problem only happens when the van is off .... ??????? help
Aug 28, 2010 at 1:53 AM
