1999 Chrysler Town and Country Can a radiator go bad?
17,800 MILES • 6 CYL • FWD • AUTOMATIC
BANANAJONES
This van is bow overheating in 80 degree spring weather.
I replaced the thermostat, which would not open when I tested it twice in boiling water.
So with a new thermostat and no other symptoms (no leaks, no unusual color to the coolant) would it be conceivable that an engine with this mileage could run cooler with a new radiator? I thought radiators were replaced only when they were punctured or leaked.
What is your experience?
Apr 25, 2008 at 7:41 AM
BLACKOP555
  • 10,386 POSTS
you can get it rodded out and flushed and you will get greater cooling effiecny also have the fins on the outside cleaned out , and it will run cooler.
vehicles require routine maintenece to keep them operating, just like any vehicle.
Apr 25, 2008 at 10:03 AM
