1999 Chrysler Town and Country
135,000 MILES • 6 CYL • FWD • AUTOMATIC
SOUTHERNBELLE112
Hi i have owned this vehicle since 2005 and have had quite a few mechanical problems, the latest being a noise or whine (i relate this sound to the public broadcasting alert signal) coming from rear end. You can hear this sound inside the vehicle while driving down the road also. Any idea what it could be?
Oct 8, 2009 at 2:20 PM
BMRFIXIT
  • 19,053 POSTS
With key on engine off do you hear the sound also
and if so suspect fuel pump module
Oct 8, 2009 at 11:55 PM
SOUTHERNBELLE112
It does it the whole time the engine is running and the noise comes from the rear end of the vehicle.....
Oct 9, 2009 at 2:31 AM
SOUTHERNBELLE112
No only whines while cranked up. With just key on it doesn't make any noise.
Oct 9, 2009 at 3:50 AM
BMRFIXIT
  • 19,053 POSTS
If it does it when 1st key on and or when engine cranking and running I would suspect fuel pump module and should have it checked
if it does it when truck moving only suspect wheel bearings
good luck
Oct 9, 2009 at 1:41 PM
