1999 Chrysler Town & Country Speedometer
FIREMANTIMBO
Was driving down the road and spedometer wound up a few times at normal speed then quit working. Since that, the transmission will no longer shift and the steering won't lock after the key is pulled. Does this vehicle have a spedometer cable? Or could it be something else?
Mar 31, 2006 at 11:00 PM
LOSONE
  • 1,616 POSTS
Does the check engine light come on? Sounds like either the vehicle speed sensor or the transmission computer. They have a medium failure rate. The computer can also be re-set by a good mechanic. Good Luck.
Mar 31, 2006 at 11:26 PM
Suggested Repair
Have a mechanic check the vehicle speed sensor and the transmission computer, and confirm whether the check engine light is on. The transmission computer can also be reset.
Conversation Summary
A 1999 Chrysler Town & Country with 120,000 miles lost speedometer function after it briefly wound up at normal speed. The transmission then stopped shifting, and the steering no longer locks after the key is removed. The owner asked whether the vehicle uses a speedometer cable. The expert asked if the check engine light comes on and suggested the vehicle speed sensor or transmission computer, noting a medium failure rate and that the computer can be reset by a mechanic.
