1998 Chrysler Town and Country Turn signals
120,000 MILES • 6 CYL • FWD • AUTOMATIC
MCERN
The left hand turn signal do not work. No light on the dash appears. The emergency flashers only flash the right side. I have check the fuse for the left hand turn signals. What else should I check?
Feb 3, 2010 at 4:35 AM
BLUELIGHTNIN6
  • 16,542 POSTS
did you test the fuse or just visually inspect it? could be faulty even if it doesn't look bad.. also check the bulbs.
Feb 3, 2010 at 8:06 AM
