1998 Chrysler Town and Country Transmission
164,445 MILES • 6 CYL • AWD • AUTOMATIC
MIMI07
When I start my car in the morning, I let it warm up for about 10 minutes. When I shift into drive, my car will NOT go forward. Actually it drifts backwards a little. I generally have to put it back into park and let it run for an additional 5 minutes and then when I put it into drive, it goes forward. I did have it checked recently and the mechanic said there were some fluids leaking and he didn't know where they were coming from. He recommended that I get a DI-test. Does this sound like a transmission problem? Is there a recommendation based on my description of what is happening?
Mar 5, 2008 at 8:48 AM
BMRFIXIT
  • 19,053 POSTS
It sound you park on an incline
check and adjust the tranny fluid
make sure u use ATF +3 or Chrysler
Mar 7, 2008 at 11:48 AM
