Sometime my car would not start, like totally dead ignition. There is no light on dashboard, head light is fine. When you turn the key in ignition no sound like totally dead. After day or two it will start without any problem. I changed module and ignition still same issue. It is not battery problem because headlight works fine try with jump still is not start.
Sent: den 19 november 2008 04:07
To: forum@2carpros. Com
Subject: RE: Topic Reply Notification - 1998 Chrysler Town and Country Starting Problem
YEs car has security system. Looks like is not starter relay.
Tuesday, November 11th, 2008 AT 8:43 PM
