1998 Chrysler Town and Country Radiator
ORLANDORIVERA
Engine Cooling problem
1998 Chrysler Town and Country 6 cyl Front Wheel Drive Automatic
I have water and coolant rushing out the bottom of my car, i cant really see where it is coming from i know it is coming out of the the left front but whati need to know weather its a hose or the actual pump
Feb 12, 2009 at 12:42 AM
BMRFIXIT
  • 19,053 POSTS
Most common for the coolant lines feeding rear heater to rust and leak under drive side in the front
(if u have rear heater )
you need to find the location
pressure coolant test will tell all
good luck
Feb 12, 2009 at 7:16 AM
