1998 Chrysler Town and Country Problem with starting
155,000 MILES • 6 CYL • FWD • AUTOMATIC
NILESHSHAH
When I start my car feel like will start try about 4 to 5 times then totally dead no lights on dashboard. HEad light working fine. No click noise on ignition looks like totally dea. I changed ignition key, module stll same issue. Car will start after 12 to 14 hours without any problem. Somebody please hel me out.-Thanks
Nov 10, 2008 at 1:40 AM
JASONRAY
  • 213 POSTS
I'm trying to understand what's happening here. The way I interpret your complaint it sounds like maybe a bad connection, maybe at the battery. Try removing and thoroughly clean the cable ends. Clean them until you can see shiny lead on the inside of the cable as well as on the post. If it's side post, clean the flat surfaces that mate. Reconnect and try again. If I'm on the wrong track from your problem, re-post and I'll try again. If I AM on the wrong track, try to be a little clearer on your description and I'll help again...
Nov 10, 2008 at 10:09 AM
