1998 Chrysler Town and Country leaking
JEFF LYON
Engine Cooling problem
1998 Chrysler Town and Country 6 cyl All Wheel Drive Automatic 200k miles
coolant tubing for rear heat and air leaking around front wheel well. tried to bypass where tubing ends by master cylinder booster, no luck-water and coolant still comes from lines i tried to bypass what did i miss
Sep 26, 2009 at 8:45 AM
BMRFIXIT
  • 19,053 POSTS
Remove and replace the two lines ,you can use heater hoses to replace the tubes
Sep 27, 2009 at 7:04 AM
