blower fan only when on high it works?
179,000 MILES • 6 CYL • FWD • AUTOMATIC
HANSEN403
I have a heater control with rear air, the front air control works only when on high. I have a new resistor for the fan which I bought after replacing the fan control module. where will I find the fan resistor to replace it? there is anther problem with the electrical. When I start the vehicle the instrument cluster goes blank for awhile. After a half hour or more with the motor running the instruments come back on. Any ideas?
Jan 9, 2009 at 8:49 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello Thanks for the donation. For the instrument panel, check the ground wires to ensure it is grounded properly. May also need to inspect the circuit board and solder any bad spots, if experienced in doing so. As for the blower resistor, below are removal/installation instructions along with the location of the component.
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_101.jpg
FIGURE 5
https://images.2carpros.com/forum/automotive_pictures/261618_fig_3.jpg
Hope this helps.. Thanks for using 2carpros.com!
Feb 27, 2021 at 2:25 AM
NEVADAKID
I just had the same problem with my 2001.......I replaced the battery (it had a bad cell and wasnt giving out enough amps)...Problem fixed!
