1998 Chrysler Town and Country buzzer noise
UKPSMILING2
Brakes problem
1998 Chrysler Town and Country 6 cyl Two Wheel Drive Automatic
There is a high pitch buzzer noise when the brake pedal is depressed to the floor. Is this a warning buzzer or something else?
Feb 25, 2009 at 6:50 PM
  • 110,246 POSTS
Is the sound in the car or coming from the outside of it?
Mar 20, 2009 at 3:49 AM
UKPSMILING2
The noise is inside around the area of the brake pedal.
Mar 22, 2009 at 7:04 PM
  • 110,246 POSTS
Hi:
I'm trying to pucture what is under there that would cause a noise like you described. I can't picture anything.
Try to look under the dash while you depress the pedal with your hand to see if you can find where the noise is coming from. Check the brake light switch (top of pedal). Maybe something is going bad with it.
Mar 23, 2009 at 3:38 AM
