1998 Chrysler Town and Country
LPASIE
Brakes problem
1998 Chrysler Town and Country Two Wheel Drive Automatic
How do you remove the rear brake drum? Where is the adjuster and what way do you move it?
Jun 5, 2010 at 1:00 AM
F4I_GUY
  • 3,302 POSTS
Hit the face of the drum with a hammer until it literally 'pop's off the hub. Once the drum is free from the hub you should be able to pull it off. If it doesn't come off, try carefully using a pry bar to help work the drum off.
Jun 6, 2010 at 12:13 PM
