1998 Chrysler Town and Country
KBALLARD
Electrical problem
1998 Chrysler Town and Country Automatic 142000 miles
Occasionally, when we start my van and take off, the odometer and similiar gauges are frozen on zero and stay that way until the van is shut off and turned on again. Now, the check engine light is on, the ABS and other dash lights are on too. Also when we start the van, it seems to make a clicking noise and the lights flicker on and off before it starts up all the way.
The starter is new in the last 2 months. Any help you could offer would be appreciated.
Thank you!
Aug 29, 2008 at 12:27 AM
  • 110,244 POSTS
Hi:
Please check with your local dealership. To the best of my knowledge, there was a TSB (Technical Service Bulletin) put out regarding the problem. The wiring under the dash is causing problems when it rubbs against other components.
See if the dealer has the info, and if you have any other questions.
Oct 6, 2008 at 1:35 PM
