1998 Chrysler Town and Country
255,000 MILES • 6 CYL • FWD • AUTOMATIC
RUBANTIN
  • 36 POSTS
The drivers side front AND rear parking lights on my 1998 chrysler T&C stopped working. Checked the bulbs, relay and fuse and they are fine. Passenger side lights, Brake and turn signal lights work fine.
Oct 30, 2009 at 2:54 AM
RACEFAN966
  • 5,029 POSTS
Have you check the turn signal flasher?
Sep 19, 2017 at 7:34 AM
RUBANTIN
  • 36 POSTS
Turn signal is working fine
RACEFAN966
  • 5,029 POSTS
Sorry my bad still have another question in mind. Did you check the light sockets? If you have a test light check for power to the socket. Let me know what you find.
Sep 19, 2017 at 7:35 AM
RUBANTIN
  • 36 POSTS
Its late will check in the morning.. I replaced 3 of the 5 lights in question with no results though.
RACEFAN966
  • 5,029 POSTS
Thats fine. All you need to do is turn the park lights on with the bulb removed and you hook up one end of you test light to a good ground and the other use to check for power at the contact in the socket. Let me know what you find and we will take it from there.
RUBANTIN
  • 36 POSTS
I realize it's been an awful long time. Since our last chat, I have hit a deer, visited my in-laws in Minnesota with health problems, dealt with serious issues at work,etc. Now that all those major issues are out of the way I can now deal with minor iones.
So, I have checked the voltage on the lights in question, and they have no power. The headlights work, the turn signals work, but no running lights on the driver's side front and rear. Also the driving /fog light on the driver's side has no power.
RACEFAN966
  • 5,029 POSTS
If you would check the grounds in the front and the rear make sure they are still intacked. We will go from there.
