1997 Chrysler Town and Country water pump
1997 CHRYSLER TOWN AND COUNTRY
MARY DOANE
In April of this year our serpentine belt was replaced. This is October and the belt came off. The mechanic said the water pump went out and needs to be replaced. I found something in your archives of questions that a belt could come off due to extra strain from another component ie water pump. We've had some issues in the past with this mechanic therefore, this is the first time I've ever tried to research something before authorizing repair. Question: your feedback on the above would be appreciated.
But mainly: "What signs would I have had that the water pump was going out? There's been no leaking. Thank You.
Mary
Oct 13, 2008 at 11:48 AM
BMRFIXIT
  • 19,053 POSTS
Did you hear any noises
coolant leak is also another sign
what we find very common is the belt tensioner gone bad it will goes the belt to jump
you may wont to ask them to check the tensioner too
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 14, 2008 at 2:13 PM
