1997 Chrysler Town and Country transmission lag
1997 CHRYSLER TOWN AND COUNTRY
180,000 MILES • 6 CYL • 4WD • AUTOMATIC
JDAVIS
ok, it started to lag about 3 wks ago. it would be in drive, would not accelerate, then after a pause would kick in. this morning it would not kick in to 3rd, speed not above 45, no check engine light came on. help? need to know what low cost fix can be done?
Jan 25, 2010 at 11:59 PM
Inspect and test all the following listed below:
Oxygen sensor
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Cap and rotor
Note if it doesn't apply,disregard.
Jan 26, 2010 at 5:00 PM
