I recently had my body control module replaced - the engine would start then die. When I picked up the vehicle it had about 2500 more miles on the odometer than I think it should have. The shop says that replacing the module would not affect the odometer. I found some references on the web that indicated that the body control module stores the odometer mileage and putting in a used one could mess up the odometer. Could the failure or replacement of the body control module have caused the odometer to change? Could it mean that they installed a used one ($690 for the part)? Is there another explanation of what could have caused the odometer to change (the vehicle was towed 5 miles to the shop.)
Jan 7, 2009 at 1:33 PM
