1997 Chrysler Town and Country HELP Won't start
131,000 MILES • 6 CYL • 2WD • AUTOMATIC
RONNYDELL
3.8L Recently bought this van, day after purchase would not start. Kept messing w/ it till it finally started & has been on & off. Check Engine light on error code P1495 (purge solenoid canister). Everyone pointed to fuel or camshaft sensor. Changed cam shaft sensor started backfiring then o.k. but still no start. Had fuel pump & filter changed, camshaft sensor changed again, along w/ purge solenoid canister. Seemed o.k. but again let it sit over night no go in the morning. This afternoon wiggled spark plugs she started right up & a few times after that. Pure Luck?? Talking w/ a friend who asked if it was hard to turn the key in the ignition & why yes it is. Could it be the tumbler or ignition switch? Any other ideas? I have spent all my money on parts that I did not need kind of feeling like an idiot right now but I need something that makes sense. The other hunch is the cam sensor towards the firewall that has the magnet to detect the camshaft is turning.
May 20, 2008 at 10:03 AM
MASTERTECHTIM
  • 4,750 POSTS
the crankshaft sensor? this is the part that usually fails. if i was going to pitch another part at it, this would be it. with a scan tool you can check the cranking rpm to determine if its working but if you dont have one then i would recommend replacing crank sensor.
Aug 30, 2020 at 5:28 AM
SAPEACHEY
  • 32 POSTS
hi having same problems, just wondering if you replaced crank sensor, did it fix problem? thanks !waynehayes12@hotmail.com
ESCHO
Having the same problem please let me know if it worked and exactly were can I locate and fix it thank you tai_jesse@yahoo.com
SAPEACHEY
  • 32 POSTS
just spoke with mechanic he said that they're pretty sure that it the security key immobilization module. SKIM) so they're trying that first, they don't think that its the crank sensor. will let everyone know how I make out
