1997 Chrysler Town and Country Battery went out
165,000 MILES • 6 CYL • 2WD • AUTOMATIC
LEEMCLEMORE
The battery was replaced and the ac and rear wiper lights are flashing when the vehicle is started. the ac works and cools. What buttons do i push to reset this? Thanks i have already sent a donation a few minutes ago. Lee
Aug 18, 2008 at 8:46 AM
RLMTEX51
With engine on set blower motor to high, set mode position knob to panel (i.e. full left), open all A/C outlets, set temperature to cold (both levers if so equipped). Now press the wash and rear wiper buttons on the A/C panel simultaneously for 5 seconds (until all LED's light). This should get the test started. Assorted lights on this panel will flash as different tests are run. Eventually if the tests are passed the rear wiper LED should be the only light flashing. Push the rear wiper button to exit test mode and you should be home free.
Aug 19, 2008 at 2:54 AM
