1997 Chrysler Town and Country Backfire/Hesitation
1997 CHRYSLER TOWN AND COUNTRY
16,200 MILES • 6 CYL • FWD • AUTOMATIC
JAMES LEGRAND
My engine just recently started hesitation and an occasional backfire. Haven't seen this in a fuel injected car before. What would be the most likely cause of this problem?
Apr 6, 2010 at 2:13 AM
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Apr 6, 2010 at 4:42 AM
