1997 Chrysler Town and Country 64 degree outlet air
18,060 MILES • 6 CYL • FWD • AUTOMATIC
SMT2713
The outlet air from my system is about 64 degrees on recirc with the outside air at 85 degrees. The suction pressure is 45 psi, the discharge pressure is 230 psi. The suction pipe is sweating and the discharge pipe is very hot. If I put the system in fresh air the outlet temperature goes up. What is going on?
Aug 5, 2008 at 12:41 PM
BMRFIXIT
  • 19,053 POSTS
Low side little high
u may have too much in the system
Aug 9, 2008 at 4:03 PM
