1996 town country van number 5 cylinder misfire
1996 CHRYSLER TOWN AND COUNTRY
DBROWN
THE IGNITION COIL IS NOT SHOWING ANY FIRE FROM THE NUMBER 5 CYLINDER. THE VAN RUNS VERY ROUGH. WHAT IS THE REASON FOR NOT GETTING FIRE FROM THE COIL FROM NUM. 5? I HAVE REPLACED IT TWICE.
Sep 14, 2007 at 5:17 PM
[quote:27e8686ca8="dbrown"]THE IGNITION COIL IS NOT SHOWING ANY FIRE FROM THE NUMBER 5 CYLINDER. THE VAN RUNS VERY ROUGH. WHAT IS THE REASON FOR NOT GETTING FIRE FROM THE COIL FROM NUM. 5? I HAVE REPLACED IT TWICE.[/quote:27e8686ca8]
You got me twisted here what did you replace? coil 2x or what,if your not getting spark from the no.5 and coil is good. Then you need to find out if the computer is firing that coil.
What type of ignition system is it distributorless or distributor or coil on plugs.
Sep 14, 2007 at 9:46 PM
