1996 Chrysler Town and Country Won't stay in gear
213,000 MILES • 6 CYL • FWD • AUTOMATIC
TNTBARIL
My van will not stay in gear. Warm or cold and any gear, it comes out of gear when you let up on the throttle. When taking off from a stop, (forward or reverse), you have to rev to about 1800 before it "clunks" into gear. While under load it's fine and no slippage. I serviced the trans with no results. It also threw the code Po731 (gear 1 ratio incorrect). I t also has a code of P1491 that reads: (Manufacture control. Aux.emission system). That is what it says on my OBD11, however the manual states: cooling fan relay circuit??? Thanks in advance!
Apr 5, 2009 at 5:48 PM
BMRFIXIT
  • 19,053 POSTS
Suspect internal tranny failure
tranny in need for a rebuilt or replace
Apr 5, 2009 at 11:08 PM
