1996 Chrysler Town and Country sister messed up
BHIPHOPHOORAY
  • 1996 CHRYSLER TOWN AND COUNTRY
  • 6 CYL
  • FWD
  • 230,000 MILES
My sister had put a little less than a capfull of 10w-30 in the transmission now when I turn the car on the engine pops and stalls out what can be the problems
Wednesday, November 4th, 2009 AT 1:17 AM
CH112063
  • 1,320 POSTS
Having only brothers I am unsure exactly how to speak with her. Check your transmission fluid in park, hot with the parking brake on. Have her help, ok. The small capful could only improve the transmission, not cause your engine to start missing. With such high mileage you necer know. Have your engine and transmission tested for codes. Sounds more like a fuel or spark timing problem in the engine.
Have it's fuel pressure tested. At that mileage many things, including the transmission are in need of servicing.
I saw someone put a half gallon of anti-freeze in a overdrive trans I just overhauled. Good thing it was not my sister, or brother.
She meant to help. Do you also have an engine problem. This is more likely.
Ok she's ok.
Thursday, November 5th, 2009 AT 8:37 PM
Related Engine Stall While Driving Content
