How do you reset the computer so the codes will read when it is taken fo an e-check?
Apr 9, 2008 at 1:24 PM
BMRFIXIT
✓Experienced Mechanic
U can reset PCM by disconnecting the battery negative side and set aside open driver door and step on the brakes
place the terminal back drive van any where from 5 to 100 miles
go and have your test
is check engine light come back on you need to have it scanned for codes and fix it before you can get a pass
Apr 9, 2008 at 2:03 PM
