Hi
if power to injectors then power to coil. Have you checked voltage at coil on Dark Orange wire? Take a test light back probe any of the other three wires at coil crank does light flash( hook clamp to power source)? If no then PCM is not grounding coil to fire and with no comm. Via data port seems PCM is faulty.
Let me know
Thanks for donate
SPONSORED LINKS
Friday, August 14th, 2009 AT 12:35 PM
