Electrical problem
1996 Chrysler Town and Country 6 cyl Automatic 125000 miles
Dashboard lights faded, blinked on & off for awhile. Then one night, the did not come on at all.
Sunday, December 7th, 2008 AT 12:30 PM
MECHANIC
Hi:
Either you have a ground problem, a loose connection under the dash, or a BCM issue. The easiest thing to check is the loose connection. Make sure the plugs going to the dash lights are tight and properly connected.
