1996 Chrysler Town and Country
1996 CHRYSLER TOWN AND COUNTRY
NATTY66
Steering problem
1996 Chrysler Town and Country 6 cyl Front Wheel Drive Automatic
how do you change a rack and pinion steering?
Jun 2, 2008 at 12:41 PM
BMRFIXIT
  • 19,053 POSTS
Remove key from ignition
raise and support the car
disconnect hoses from steering gear
remove front wheels
separate tie rod ends from steering knuckles
disconnect engine damper strut from crossmember ( if equipped )
support front suspension crossmember using floor jack
remove front suspension crossmember bolts
lower front suspension crossmember so steering gear can be disconnected from steering column
remove steering retaining bolts
remove steering gear
steering column coupling will disconnect from steering column
Jun 2, 2008 at 1:20 PM
