1994 Chrysler Town and Country belt tensioner
ALWAYS WORKING
Engine Performance problem
1994 Chrysler Town and Country 6 cyl Two Wheel Drive Automatic
how to install a belt tensioner
Mar 6, 2009 at 7:08 AM
MIKE H R
  • 3,094 POSTS
Is the tensioner bad or the bearing in the pulley. Most times it is just the bwearings that go bad in the belt tensioner pulley. You will have to remove the belt, then using a socket and wrench loosen up the pully itself. It is like changing any other pulley. After replacing it turn it just to make sure it on straight. then replce the belt.
Mar 10, 2009 at 2:41 AM
