1994 Chrysler Town and Country
1994 CHRYSLER TOWN AND COUNTRY
ALWAYS WORKING
Engine Performance problem
1994 Chrysler Town and Country 6 cyl Two Wheel Drive Automatic
how to install belt tensioner assembly in 1994 town and country
Mar 6, 2009 at 6:54 AM
  • 110,240 POSTS
I believe there is only one bolt through the center of it that holds it in place. Remove that and see if comes off.
Mar 20, 2009 at 3:43 AM
CARADIODOC
  • 34,367 POSTS
Jacobandnickolas is right, but there's a 15mm nut on the back side of the mounting plate, kind of behind the power steering pump. Crawl under the van, behind the cross member and reach up to find it. You might have to do it by feel. Also, there isn't much room to swing a box wrench so if the wrench is butted up against something and you can't turn it further, you might need two different wrenches from two different manufacturers. I had a Craftsman and I borrowed a Snapon. The position of the teeth was just different enough that when one wrench was turned as far as possible, the second wrench would turn the nut a little further so the first wrench could get another bite. Sockets usually didn't work well due to the confined space.
Be sure there is no dirt or debris on the mating surfaces when you put the new tensioner on. As little as 1/16" misalignment on the pulley can cause a belt squeal.
caradiodoc
Mar 22, 2009 at 2:16 PM
