1993 Chrysler Town and Country Please help my SICK van!
96,000 MILES • 6 CYL • 2WD • AUTOMATIC
VAN4AIDAN&CADA
  • 7 POSTS
The PROBLEM is that my van seems to skip, cough, hiccup, stall, or whatever term seems appropriate and sometimes would even cut off. In the beginning, it only did a few times and clear up after driving for a little while. At first, I thought I had gotten bad gas, so I used gas treatment. This seemed to help... I drove it to Illinois from Alabama with only a little trouble out of it. The van only sat for a day before I drove it again and now the problem is even worse! The jolting is really bad. I've noticed that the speedometer will jump from 60 to 20 or even 0. The cold air gets almost hot. These happen when the van "skips". Two days ago I also noticed that sometime when I left off the gas a whistling... There are NO LIGHTS on to check the engine. I can left off the gas or press the brake and it will stop "skiping". This problem is not ALL the time, but it seems like it's heading that way fast! Today on the way taking my son to speech therapy was the worst of all! To top it off the serpentine belt came off. We fixed that! Got home and tried to leave again and now the waterpump is leaking and there is water on the plate around where the head gasket is. I can't afford to take it to a pro, but my husband can fix most anything on a vehicle. He's stumped as to what the ailment is, and so is everyone else that we have talked to! Please help us!!!
Jun 23, 2009 at 10:55 AM
  • 110,248 POSTS
What plate is the coolant on? Is the intake manifold?
Jun 24, 2009 at 3:44 PM
VAN4AIDAN&CADA
  • 7 POSTS
It's on or around the head below the valve cover. To me it looks like it might be splash back from the water pump. Haven't had a chance to check yet to see if a hose is busted or loose or if the waterpump is broke... Thanks for your promp attention.
Jun 25, 2009 at 3:53 AM
VAN4AIDAN&CADA
  • 7 POSTS
got the belt and water leak fixed. Sitll having the skipping or hesitation problem... Driving along fine and starts to hesitate or skip or whatever... Speed jumps around. Drove tonight and noticed when it does it's thing that the lights dim when it happens. Fuel treatment doesn't help... Someone suggested "crank sensor"... Another suggested it needed a "GOOD" tune-up... Any suggestions? The jerking is driving me and my 1 year old crazy, but my 4 year old loves it!
Almost forgot! When it starts to stall or hesitate, I can let off the gas and the jerking and crazieness will stop. Can press the gas and let off again, this will help for a few minutes. The van is still cutting off too... It will restart with no problem! Please help me!!!!!!!
Jul 4, 2009 at 6:47 PM
