If I have a leak in my fuel line that is pushing out quite a bit of fuel, or at least more so than I have sene on other fuel leaks, will this cause stalling at certain speeds. I typically see this stalling at idle, at below 1000 RPM, until I have gotten the engine to normal (hot)operating temp, then I have to keep the van at about 3500 rpms to keep the engine running. Are these high pressure lines? Is this why I am having this issue? I should mention that I thought it was oil related as the oil pressure was flickering on and off which I associated with oil, so I replaced the pan (dented bad) the pickup, pump and oil pressure sensor.
Mar 21, 2008 at 7:40 AM
