2003 Chrysler Sundance battery replacement
MYEUBANKS
2003 Chrysler Sundance 4 cyl Front Wheel Drive Automatic
How do you replace the battery on the cruiser?
Jul 15, 2008 at 2:02 AM
  • 110,248 POSTS
Hi:
First disconnect the battery terminals, neg first. Make sure not to touch both post at the same time with anything that can conduct electricity.
Next remove the battery hold down. Now you should be able to remove the battery.
To replace it, just reverse the process.
Oct 16, 2008 at 2:33 AM
