1988 Chrysler Sundance Running rich/taking in too much gas
117,000 MILES • 4 CYL • FWD • AUTOMATIC
CKIM2691
I've checked the vacuum tubing and replaced all of the ones that are connected to the fuel injector. I've done a regular tune up. I'm not losing any power and it's not giving out any black smoke. I can definitely smell how rich it's burning though. Could it be the fuel injector itself or maybe something else?
Aug 23, 2009 at 6:31 PM
  • 75,988 POSTS
Possible causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
Aug 23, 2009 at 6:45 PM
