2002 Chrysler Sebring Check Engine Light
WILLIE63640
My mom owns a 2002 Chrysler Sebring and the EIL is on steady. She took it to Dobbs and they ran a diagnostic series on it and told her that her gas cap was not on tight enough. The tightened it and the light went out. Two days later, the light came back on and she took it back and they told her that the diagnostic test was ran again and there was nothing wrong with her car. She went and got a new gas cap, had it put on and the light went out. One week later the light came back on and is steady burning. The problem is that she will have to have the emission control testing done and has been told that the car will not pass because of the light. What can we do to get the light to go off and stay off???????
Jun 7, 2006 at 10:37 AM
JDL
  • 16,098 POSTS
Sorry about the late reply.
If the gas cap isn't causing the problem, you will have to check for emissions leak, elsewhere in the system. If it is the cap, try some thread tape right before you get it tested. See if helps, once you pass the test, remove the thread tape.
That isn't the proper fix, but, it might get you out of a bind if the cap isn't sealing for some reason? If that sounds like a momentary shadetree fix, it is.
Mar 15, 2015 at 3:55 AM
Suggested Repair
If a tight or new gas cap does not keep the light off, have the evaporative emissions system checked for leaks elsewhere. Thread tape is only a temporary, improper workaround and should be removed after any test; it is not a lasting repair.
Conversation Summary
A 2002 Chrysler Sebring has a steady engine indicator light. A shop first blamed a loose gas cap; tightening it and later installing a new cap only turned the light off temporarily. The expert says to look for an emissions leak elsewhere if the cap is not the cause, and notes that thread tape might help only briefly and is not a proper fix.
