It sounds like the lock rod from the door tumbler has fallen off. Then best way to fix this problem is to remove both front seats so you can get the door panel off. Then look inside the door to check the lock rod.
Here is a guide to help you get the door panel off.
https://www.2carpros.com/articles/door-panel-removal
Check out the diagrams (Below)
Cheers, Ken
Images (Click to enlarge)
Jan 18, 2018 at 8:02 AM
