2007 Chrysler Sebring car is running hot...
52,946 MILES • 4 CYL • 2WD • AUTOMATIC
ROCK2G3
Whats can cause my car to overheat?
Feb 26, 2009 at 4:47 AM
ZACKMAN
  • 4,202 POSTS
Insufficient coolant quantity in cooling system
Insufficient coolant quality in cooling system
Leaking cooling system
Faulty (stuck closed) thermostat
Faulty radiator cap
Faulty water pump
Kinked radiator hose
Faulty or insufficient cooling from radiator fans
Faulty cooling fan switch
Faulty engine coolant temp sensor
Head gasket leak
Sludge in cooling system causing blocked coolant flow
And several others. We may be of help with more details to the problem.
Feb 26, 2009 at 5:28 PM
