2006 Chrysler Sebring Changing Brake Pads
49,900 MILES • 6 CYL • 2WD • AUTOMATIC
SBAYNER72
I looked on YouTube.com to see if anyone had tutorials on changing brake pads. There's quite a few that make it seem very simple. Is it? Is this something I could handle myself? I am mechanically inclined, change my oil, have changed a thermostat, air filters, cabin filters, etc. None of the videos mentioned bleeding the brakes. Is this necessary?
Thanks.[img:419158016b]http://www.2carpros.com/forum/automotive_pictures/509090_sebring_1.jpg[/img:419158016b]
Mar 29, 2010 at 2:47 PM
BLUELIGHTNIN6
  • 16,542 POSTS
unless you disconnect a brake hose then no need to bleed them. its pretty straight forward, simple to do brake jobs. are you just replacing the brake pads or you replacing the rotors as well?
Mar 29, 2010 at 2:50 PM
