2005 Chrysler Sebring
NEENW
  • 2005 CHRYSLER SEBRING
  • 4 CYL
  • FWD
  • 148,560 MILES
My 2005 sebring reads camshaft sensor when put on machine. Had that fixed in november. Now engine lights stays on and still sputters around at each excelaration. For the most part it won't go pass 62mph. Now when driven for along time it will cut off after idoling roughly. Some say ecu/ecm unit but want some other subjection.
Wednesday, April 14th, 2010 AT 7:07 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Go by your local parts store and have them pull codes, write them down and post.
Wednesday, April 14th, 2010 AT 7:16 PM
Lack of acceleration, chugging, hesitating, bogging etc. Could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Wednesday, April 14th, 2010 AT 7:18 PM
ERNEST CLARK
  • 1,730 POSTS
To definitively isolate the cause of your problems can be done in a much easier and less time intensive manner by performing a "Drive Test" with a capable scanner and a technician with the skill to interpret the data.
*Note* All scanners aren't created equal. Your standard "AutoZone" scanner won't do this job.
This may cost you a little more up front, but believe me, it'll cost you waay more in the long run if you manually inspect every single component on your engine that could possibly cause a drivability issue.
A drive test will display all of your engine's operating systems as they function in real-time and will graph thier data which can then be compared to factory specs. If any system (ignition, fuel, computer/sensor) is performing out of spec, it'll be easily pin-pointed by a technician with experience. This will get your issue solved and leave no doubts.
Sunday, April 18th, 2010 AT 8:15 AM
