2004 Chrysler Sebring valve cover gasket
118,000 MILES • 4 CYL • 2WD • AUTOMATIC
WYTEGURLTAMI
I'm wondering approximately how much it should cost to replace a valve cover gasket & is it possible to find out if your head gasket is blown without taking it apart
May 19, 2010 at 4:40 AM
BLUELIGHTNIN6
  • 16,542 POSTS
a quick test for the head gasket would be to remove radiator cap * WHILE COLD* then get in and crank engine over. if coolant blows out of radiator cap opening then most likely head gasket is bad.
the valve cover gasket repair will be approx. $100 , including parts and labor.
May 19, 2010 at 5:40 AM
