2004 Chrysler Sebring the rpm is not enough
71,000 MILES • 6 CYL • FWD • AUTOMATIC
JUANDBUENDIA1
i already change the engine with new water pump, and new oil pump. The engine was around 100000 miles.I changed the crankshaft sensor and the camshaft senser. I already checked the primary timing chain a lot of times!I alredy check with the scaner. When i try to give it more then 2500 rpm the engine does not respond.like if it didnt enough fuel. i alredy checked the fuel pump. and i do not now what else to do
May 19, 2010 at 4:39 PM
  • 75,988 POSTS
Hi juandbuendia1, Welcome to 2carpros and TY for the donation
Check and test the throttle position and manifold absolute pressure sensors. Also check exhaust for restriction and verify ignition timing
May 19, 2010 at 7:12 PM
