2004 Chrysler Sebring Rear ball joint removal
100,000 MILES • 6 CYL • FWD • AUTOMATIC
BJJB211
what is the easiest way to remove the rear upper ball joints
I do not have a torch or special removal tools
I am working out of my garage
Aug 22, 2010 at 10:59 AM
BLUELIGHTNIN6
  • 16,542 POSTS
is this a non-coupe or a coupe style Sebring?
Aug 22, 2010 at 11:07 AM
BJJB211
this is a 4 door -- 2.7L -- non-convertable
sebring touring
Aug 22, 2010 at 11:23 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Thanks for that info. The rear upper ball joints on this vehicle are pressed into the entire rear upper control arm assembly. To replace the upper ball joint, you would first have to remove the rear upper control arm. Once removed, the ball joint assembly would have to be pressed out of the control arm using an arbor press.
Aug 22, 2010 at 11:29 AM
BJJB211
Thank you
Aug 22, 2010 at 11:51 AM
