2004 Chrysler Sebring oil pump
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
MIKE STENGL
Oil light comes on when at idle...goes off with slight increase in RPM.Oil is full. Possible pump? How difficult is repair if pump is the problem?
Sep 25, 2009 at 11:22 AM
BLUELIGHTNIN6
  • 16,542 POSTS
could be weak pump or faulty oil sending unit / sensor. i suggest connecting a mechanical oil pressure gauge to ensure oil pressure is indeed low at idle. if so replace the pump.
Sep 25, 2009 at 11:48 AM
