2004 Chrysler Sebring OIL PRESSURE SENSOR
79,000 MILES • 4 CYL • FWD • AUTOMATIC
PLANETAVILLA
I have a 2004 chrysler sebring 2.4L and at first I was noticing that I was having a small leak under my engine and I located it where the oil pressure sensor was located. I have removed and changed the sensor, but it seems that it still leaks. I check it by feeling under the sensor and there is where it still leaks.
On the sensor the threads stop and there is a space about 1/8 to the housing of sensor. Should it be tighted flush all the way to the engine block or should there be small space in between the sensor and the engine block.
Any help to resolving this leakage and to stop the drops I am starting to be annoyed of on driveway.
Thank;
Apr 6, 2009 at 3:51 PM
  • 75,988 POSTS
Could be a washer missing. Try this use a teflon tape and see if it works
Apr 6, 2009 at 6:45 PM
