2004 Chrysler Sebring IDLE
70,000 MILES • 4 CYL • FWD • AUTOMATIC
STEVEPRANKERD
V bad Engine miss approx every 5 / 10 secs always.
Engine at idle in drive, much worse with a/c on. in park better. A/C off a lot better, but still occasional miss.
Changed coil block, plugs and plug wires twice...( with new ) no better.
I think all 4 cyclinders actually stop firing for a second, ( not just one ).
Jul 31, 2010 at 11:47 PM
  • 75,988 POSTS
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Aug 1, 2010 at 12:17 AM
