2004 Chrysler Sebring gears
93,000 MILES • 4 CYL • FWD • AUTOMATIC
TGINNINGS
When my car is cold first thing in the morning, it will not shift into drive. The gear shift moves, but it takes a minute or two of revving the engine to get it to kick into drive. Then sometimes car feels like it kicks back out of drive & loses power after I start driving. This only happens when the car is cold enough to be frosted or iced over, and after it goes into gear, is usually fine for the rest of the day. Any ideas what is causing this? Thank you!
Feb 13, 2008 at 11:16 AM
BMRFIXIT
  • 19,053 POSTS
Well as a 1st step I would change the fluid and filter making sure using the correct Chrysler approved tranny fluid
good luck
let me know
Feb 13, 2008 at 11:42 AM
