2004 Chrysler Sebring charging system problem!
5,800 MILES • 6 CYL • 2WD • AUTOMATIC
ABB
  • 7 POSTS
Hello. I have 2004 sebring with 2.7L v6. I just replaced the engine coz the previous owner did n't change the oil, and now the alternator is not charging the battery. I'm not sure if I forgot to connect a ground wire somewhere or the voltage regulator inside the pcm is burnt, any help please.
Thanks a lot
May 21, 2008 at 4:52 PM
  • 75,988 POSTS
Get the battery and alternator load tested if it checks out-you could be right with the field generation control with the PCM. Double check all connections involving the alternator and battery.
May 21, 2008 at 6:46 PM
