2003 Chrysler Sebring Wont Start
103,269 MILES • 4 CYL • FWD • AUTOMATIC
ROBERT3674
I got off the turnpike got to the light the light turned green steped on the gas car stalled out and wont start after that put gas in the car still wont start what could be the problem. it will try to turn over but wont.
Oct 7, 2010 at 1:21 PM
  • 75,988 POSTS
Cranks but no start condition-do below to determine whether it's fuel or spark issue:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Oct 7, 2010 at 1:58 PM
